Hello All,
I am new to this forum so if this problem has been addressed, please let me know. I have a 2010 Carolina Skiff with a Yamaha F115 4 stroke motor. It has been in the shop 4 times in the past 2 weeks for a power issue. When I attempt to go full throttle, I bury the stick and I only get 3800 RPM @ 10MPH max. The filters and separator has been changed 3 times, the plugs twice and the injectors have been cleaned. When I get it back from the shop, each time it runs great for a day and then if I put fresh gas in the tank, it bogs down again. It has a Yamaha water separator on it and all OEM parts. The motor has about 20 hrs on it total. When I check the water separator, I found small white milky bubbles in the fuel, but no water at the bottom of the jar. Any Help would be greatly appreciated because the guys at the marina are baffled too.
