07 90 hp. 4 stroke long term storge question
  • 07 90 hp. 4 stroke long term storge question
    I need to store my boat and motor for 4 years. its a 90 hp. 2007 4 stroke on a g3 16' boat with side consul .
    what do I need to do? thank you
    ant
    here is a pic
      here is the lable
        sell it and invest the money and buy another in 4 yrs.
        there is not a good way to store it that long.
        if I tried to store it that long.
        change the oil and filter add a bottle of crankcase store n start and run it ten min.
        drain the carbs via the drain screws.
        blow out the fuel lines and pump,drain the filter,drain/blow out all the lines between the engine and tank.
        empty the fuel tank.
        remove the lower unit,remove the water pump impellor.
        leave the lower off and tape or bag the lower part of the midsection.
        tape/bag the hood and idle relief and tell tale outlets.
