I have an 05 T60. Does anbody know if this will run without the battery hooked up? If the motor was charging shouldn't I be able to unhook the battery while the engine is running? I put a volt meter on the battery terminals and it shows around 13 volts running or not. Shouldn't the voltage be higher if the motor is running? Ay help would be great
