Hi Everyone,
I recently purchased a 280 Baja Sportfish with a pair of 200's SSW 2 with carb's. Engines were replaced in 2003 with brand new Yamaha crate motors. The problem or possible problem I'm having is the port motor consistently uses more oil from the tank, almost by double. Now the question is, is the port motor using too much oil? Or is the starboard motor not using enough oil?
Thank you in advance for any input.
