The oil pump in the oil reservoir will not shut off. It keeps running. The one on the motor runs over and comes out on the hose overflow. Which pump is bad? Thank you bobby
2000 Yamaha 115
seems the pump is working otherwise it would not be moving oil.
You have switch, wire , and/or con*****er problem.
Start with looking at gauges to see what they are telling you and
do some searching on the forum past posts, this has been covered many many times.
Rodbolt17 has posted very good troubleshooting /explanations on the system
