Hi there
I wonder if someone on here can help.
I have a 1998 150 vmax carburettor and have had a couple of problems.
I was out on Tuesday morning and noticed the engine was running very rough between around 800 to 1400 rpms. I suspected that there may have been some dirt/gum in carbs from the winter storage period so sprayed some cleaner into them to try to sort that out. I then went to take the boat for a run to try to clear them through. I brought the boat up onto the plane and ran for a little while at around 4-5000 rpms and it went well. It was still rough around 800 to 1400 rpms but as soon as i was over the 1400rpms it seemed to run as normal. However as we came off the plane the engine died. I could restart it but I didn’t have sufficient power to put it in gear and keep it running. I then took it into the local marine mechanic yesterday morning who took the carbs off and cleaned them through. This seemed to resolve the issue however he was concerned that there may be a further electrical problem. I would also add that I have a Yamaha 10 micron fuel filter installed and I replaced the element around 3 weeks ago.
The boat ran fine for most of yesterday and we went out for a little evening cruise. After around an hour, I dropped the other guys off at the pontoon. When I came to restart the boat to take it back to my mooring there was nothing – the engine wouldn’t start, tilt and there were no gauges. It was as if everything was dead. I have had this problem once before and found it to be the 20A fuse blown on the port side of the engine so I immediately changed this fuse but this didn't solve the problem. I also went through all of the other fuses but this didn’t resolve the problem - there was still nothing. During this time the other electrics on the boat all worked fine however – sounder, nav lights and bilge pump so presumed it couldn’t be the battery. About 30 mins later after moving the boat to a temporary dock with our tender I tried the key and the engine started, tilted and all gauges worked and the engine ran fine.
I’m wondering whether anybody has any ideas on what this could be? Could something be overheating?
Thank you in advance for your help
Nic
Nic
