30hp yamaha 3 cylinder issues. help?
  • 30hp yamaha 3 cylinder issues. help?
    30hp yamaha. Wouldnt go into forward gear. Found loose linkage. Wouldnt go still. Go towed in. Tried the motor again next morning.. Worked.. But when pulled into shore and lifted motor it had a creamy substance coming out above anti ventilation plate area from a hole/ drain port that showed it was oily on the water. Any ideas what could have happened.. ?
