Hello, I have recently purchased 2 Yamaha Enduro 40 hp electro start and remote control for my 50 feet sailing catamaran (now with about 100 hrs. of use). They are located in boxes to minimize the noise and the weather exposure. When I start them, they smoke a lot and if the boxes are closed it seems that the smoke soffocates the breath of the engines and they stop. I use yamalube 50:1 but seems to be too much. I check the spark plugs and they look black and oily. I don´t let them running on tickover for more than 2 minutes but the problem persist. I never use them at full throtle so, can I reduce the mixing rate to 40:1? Does it help? If I leave the boxes open they don't stop but they produce a lot of white/blue smoke. They work perfectly when I give more throtle. I use original spark plugs. Where is the problem?
Another problem: In choppy conditions lets say 1 meter waves or more, when the back of the boat sinks on a wave, the engines stop. Is the water level flood any air intake that causes the problem. They start inmediatelly.
Thanks for your help.
