My motor will not rev above 4900 RPM. It runs great , just will not max out. I have the factory prop and engine mounted as it always was. Normal RPM was more like 5700 RPM and almost 50 MPH now 4900 max and about 39-40MPH as per GPS.
I ran the Yamaha cable and software to the motor, no codes, everything working properly. Killed each cylinder at idle and clearly see how the motor would run with a cyl down.
I have changed the HP pump screens, VST tank screen, medium pressure filter. low pressure filter and both block mounted fuel pump. I have also installed a new racor 10 micron filter.
Any ideas where to go from here? I was hoping to find a clogged HP pump screens, but that wasn't the case.
Even if I tilt the motor out of the water while running the revs stay at 4900 and do not climb.
Thanks in advance.
Thanks in advance.
