Yamaha Carb Pilot Screw Adjustments
  • Yamaha Carb Pilot Screw Adjustments
    I would like to know how to adjust my Pilot Screws on my 3 carburetors when rebuilding my 1995 C75TLRT Yamaha outboard motor carburetors.
    Thanks so much,
    Capt. Paul Cason
    If they are the screws I am thinking of....
    Before you tear carbs apart for rebuild. Label the carbs. Then count the number of turns it takes you to bottom out the screw, from where it is currently set at.
    Do this for each screw on each carb. Write it down. Then remove screw.
    After rebuild, turn the screw in until it bottoms out again. Then back the screw off the same number of turns you wrote down. This should set it back to its' original setting.
