Age of outboard if possible. 70hp 2 stroke
  • Age of outboard if possible. 70hp 2 stroke
    Hi, can anybody give me an estimate of the age of the outboard that was on a small boat I bought recently. I need to do a bit of maintenance and want to know what model etc I am working on. It is a 70hp 2 stroke Pic below
    http://www.yamahaoutboardparts.com/a...1&d=1370963967
    I am after a pdf manual for the engine as the power tilt and trim is not functioning properly. It may just need hydraulic fluid but Im not sure how to check or where to put it in.
    here's a pic of the hydraulic kit
    http://www.yamahaoutboardparts.com/a...1&d=1370964818
      I can give you the exact year of manufacture.
      Post the info of the sticker that usully in on the bracket
      EX: 70*** Code*** S/N *******
        Originally posted by mercanlandy View Post
        Wild guess, not much use to you, but somewhere between 87 and 91 from the Looks of it
          Hi, thanks for reply. I will look for the for the sticker and get number at weekend then can let you know.
            Thanks for info, I can try and get the info I need now
              By the cover it's late 70s very early 80s.
                Date Code...
                Hello,
                On this page, upper RH corner, next to the picture of the gentleman urinating on the set of 350's, click on the "Yamaha Genuine Parts $ Accessories" logo.
                On the page it brings you to, there is an explanation of the model number code including model, setup, length, and Year of Manufacture.
                Bon Chance!
                If its got teats or tires, you bound to have trouble with it....
