Tilt and trim unit
  • Tilt and trim unit
    I have a c85tlrt engine mounted with a 6h1-13 tilt and trim unit. The unit stuck in the up position at the boat ramp and we bled out the system prior to locating the manual bypass. Stupid. I refilled and bled as best I could and am now into the motor and pump assembly. I discovered the plastic pump coupler is stripped but the pump drive shaft is very difficult to turn with pliers. I think the pump is bad and want to replace it. I am stymied by the four screws holding the pump in. It looks like a hex but a 3/32,7/64/, and 1/8 do not fit well. The smaller ones rolled and the 1/8 won't go in. A t15 torx fits somewhat, still a little loose, and accepts moderate torque but I can't break them and fear getting much more aggressive.
    I was hoping I could replace the pump, bleed, and be on the water quick and for maybe $300. Vs the $3200 the dealer quoted me for a new one. They wouldn't even work on the unit like I am trying!
    Any ideas or suggestions are much appreciated! .
    Thanks for the help! Not.
    Finally got it going and learned a thing or two along the way. Spent about $20 in parts. Dealer wanted $3200. I feel good about the way it turned out.
      What did you have to do to fix it (I have no idea..)?
        things made overseas are usually metric so need to use the proper tools.
        I am sure the service manual would give that info
