Auxilary circuit?
  • Auxilary circuit?
    Hello, I am new to Yamaha just this last year.
    I was doing a through inspection of the powerplants before re launching.
    I found the 80 amp fuse links and a spare in the cover of the e box. I noticed that one of the fuse links seems to go nowhere to an unused and capped plug.
    What is that for? Is it a service connection for diagnostics?
    Just curious, seems like I could use that fuse in a pinch, after arcing out available spares.
    That would be the alternate charge lead, if you have 2 batteries you could hook that to the other battery. Yamaha makes a lead that plugs right into it with a inline fuse just for this purpose..
      its for the battery isolator circuit.
      a mysterious thing that hull manufactures and riggers don't know exists.
        Thank you both for the answer to the mysterious wire.
        Now that I know about it (and the riggers and manufacturers don't) I'm gonna use it for evil purposes....
        Can someone confirm that the part I want it item #61 p/n 67H-81949-00-00 WIRE, LEAD or is it item #25? I think item 25 is what I saw on the fuse assy.
        2000 SX150TXRY Yamaha Outboard ELECTRICAL 3 Diagram and Parts
          you need to get the harness from the 2013 yamaha mrp book, i dont think it is in the parts catalog..
            Thank you Sequoia.
            I will try and look it up there.
            Good day.
