I have a 703 con*****er that has a bent and broken pin on the female connections. It saw some twisting at one time and bent the pins, and one ended up being broken off. I have pushed it back in it's slot and it holds until you wiggle it. Do you think this is making a connection? Can I fix this with solder, or can I buy just the wiring with the female plug? This is probably carnage that none of you have seen. I bought the motor and control for a deal.
703 control with broken female wiring pin fix
