yamaha150 four stroke fuel issue
  • yamaha150 four stroke fuel issue
    New to the site like to say hello
    Had the boat out everything running fine while making bait motor stalls and won't restart. Drop anchor pull cowl after some trouble shooting find no fuel pressure at fuel rail and can't hear fuel pump for 3 seconds when key is put in on position. Any thoughts as to where to start? from what I read the fuel pumps don't go bad to often
    motor is a 2006 Yamaha four stroke 150
    check the fuel/ign fuse,fuel pump relay and fuel mp.
    pu
      After trouble shooting and finding power at fuel pump pulled intake and vst found small black particles in the vst tank and on pump filter going to order new pump and should be back on the water
