here goes...boat starts right up at home and right at the dock, but after running the boat for app. 25-30 min. boat cranks and almost starts, but will not unless I can manage to slip it into gear enough to it seems give it gas and it sputters and within 10 seconds is running normal but this isn't always effective and my last trip out I pulled the cover out of desperation and depressed the shifter switch several times and I believe it fired up but then it ran like cylinders were missing, like it does when the shifter switch is going bad. Only way clear that is to turn off the motor and try again. Finally started on all cylinders and ran 10 miles home,running strong but I knew not to shut it off. Get home hook up the muffs and it fires right up, strong.
Note, boat has been worked on by reputable certified Yamaha Mech. who recently after going through fuel and electrical systems found clogged fuel filters to be the culprit of abrupt power loss when throttling up. That problem went away. The filters where not too bad I saw them. Right prior to this I took it to a bad Mechanic who said my shifter switch was bad as well as my throttle and shifter cables so he replaced them. I have since found in the engine tray the throttle cable cotter pin, and on the other side of the engine, another small cotter pin in the bottom of the tray that came from a small nylon ball/snap assy. that is attached to a linkage. I have also moved that as my wife cranked the engine and once it did help start but gas/oil did spray out the exhaust when it did. New shift switch to be here today cause that thing has given me trouble from the first week I bought the boat and Im thinking that because even when the boat does finally start, it exhibites the symptoms of a faulty switch at times now. I need to resolve this.
Why start right up, run strong, reverse,foward, fast,slow, run for 5,10,15 minuts,turn off and it starts right up, but go 25 or 30 min+ and its as I said, almost, but seems to need throttle or something..Thanks this is so long winded..breaking down sux!
