my tacho not working stuck at 7000+ rpm
  • my tacho not working stuck at 7000+ rpm
    I got a 95 Yamaha 70 hp, it has the traditional tacho.
    when I put my key in, tacho shows 0 rpm (in both on and off position)
    but as soon as the engine starts, it jumps to over 7000-rpm and stays there. no matter what happens the tacho is at 7000+ rpm if the engine is running.
    PS. the engine runs completely fine not over-revving.
    I've replaced the CDI and done the wiring and still the same, could be something short-circuit or something ?
    why was CDI replaced?
    I thought the tach signal for that motor is from charging system.
    I think you have a problem with tach
    Have no idea what tach you have but here is something from Faria on tach problems http://faria-instruments.com/site_ma...achometers.pdf
      Check the wiring and terminals on back of tachometer for corrosion, loose or improper connections....
