2003 225 sws2
  • 2003 225 sws2
    Hi,
    I have a 2003 SWS 225. Put it in the warter ran fine first time. Second time diffivult to start would run ot idle then cut off. Finally got it going was fine for the rest of day. Since then it will start briefly then cut off and will not start after that. Checked oil, gas filter everything seems fine. Is there a place to introduce starter fluid to see if it is a gas problem. Any help will be greatly appreciated
    Sounds like your fuel system is in need of help. Might want to search OX66 and start reading. When's the last time the VST was cleaned? O2 sensor?
      2003sws 225
      Thanks I will check
