115 oil leak
  • 115 oil leak
    I have a 2001 4stroke 115 with a oil leak that comes from front of motor. It is worst when motor is tilted. I have taken the powerhead of but I can see no indication of oil. The oil pump seal is clean. I need some help..
    You will have to try and see where it is coming from, may be coming from engine or below engine block in oil pan area.
      there was a recall on the oil pumps about that year.
      it was due to poor sealing at the pump.
      could also be a bad cam seal,bad crankcase seal or bad lower crank seal.
