need compression, good spark, proper timing of the spark, and proper fuel to air mix for cylinder to fire.
Compression, spark and timing are all easy to test and then you are left with the fuel if all else is good
that's why I had to ask the choke question.
BET indicates this is a non US market motor.
US market 70 HP from 92 up use an enrichment setup known as prime start.
on yours physically observe that the choke plates completely close,and stay closed,while cranking.
thanks for all the replys how do I check the timing.
