2004 F150C won't start, trim and tilt work
  • 2004 F150C won't start, trim and tilt work
    New here, having some trouble trying to start my 150. Turn the key and nothing happens, no crank or click. Was told that I needed an ignition switch, so changed it and nothing changed. Had checked the fuses on the engine all were good. Battery is good and figure the connections are also, because the trim and tilt work. When changing the ignition switch, forgot to disconnect the battery, dropped a screw caused a spark and blew the 20amp fuse for the engine control unit. Hope I did not mess things up worse! I guess if I blew a fuse, the wiring to the engine is fine. Not sure where to look next, was told that if the starter was the issue, there should be a clicking noise. Any help would be greatly appreciated.
    check neutral safety switch that keeps motor from starting in gear
