Engine is an 84 model 115 hp Yamaha. My remote oil pump stays on. Mechanic said the main tank oil sensor is likely bad. Looks like an easy fix...just get a new sensor. In the meantime, can I disconnect the electrical leads to the remote
tank and manually fill the main tank as needed. I will be getting the sensor as soon as possible, but would like to use the boat in the meantime.
I noticed the red quick connect from the sensor to the control unit was disconnected. I hooked them up and upon turning the key to just the on position, the buzzer alarm went off. I disconnected the same lead again. I pulled the main oil sensor part-way out of the tank just to see what it looked like basically and pushed it back into place. Turned the key to the on position again and the pump turned on just as before. This time though, when the pressure built up enough it popped the oil sensor off the top. Not sure where it was leaking out before, but I assume it would have been the breather hose.
Looking at the manual (aftermarket manual) it shows a circlip at the base of the sensor unit. Not sure if this applies to my year model or
not but I see no possible way of removing or securing any time of clip to the base of the sensor unit. What can I do to better secure the sensor onto the tank?
I'm now feeling a little nervous about replacing this part myself.
