1988? 6hp longshaft
  • 1988? 6hp longshaft
    Got a3.25m dinghy which came with a longshaft Yamaha 6hp which is way to long for the boat.I want to convert to shortshaft. Is there a kit available??
    Would have to replace drive shaft, shift shaft and water tube. Would have to remove 5 inch extension block between lower unit and mid housing, if doesn't have the extension then would also need to replace mid section.
