F115 2002 injectors
  • F115 2002 injectors
    Looking at removing the injectors on my F115 ( 850 Hours ) and getting them cleaned and checked.
    Would it be advisable to replace the rubber gasket/seal on each injector ?
    On the parts list there is a rubber gasket/seal 68V-13766-00-00 YAMAHA RUBBER, INJECTOR $8.70 . I found a piece on you tube showing servicing a F115 injector and it looks like there is a seal on each end of the injector. Is that correct ? I cant see a part number for the one on the fuel rail side.
    In the workshop manual it shows an O ring and a rubber damper for the rail side and a rubber seal for the engine side.
    Just wanted to check and order them before I remove them. ( don't want too much down time )
    Thanks in advance.
    In addition to the rubber would need 68V-1410B-00-00 packing, one per injector removed.
      if all are in good shape, they can be reused.
