I replace the water pump impeller to my 2004 or hp 4 stroke yamaha motor due to No Water Discharge coming from the discharge port when checking to see if I had depleted the problem after replacing the impeller it still remained the same. Someone mentioned that they have had the same problem but found that the discharge port was plugged. Could that be caused the impeller that I removed did look some what good in condition and that it would shoot at least some water from the port. How do I clean the discharge thoroughly if so.
F40TLRC No water discharge
Originally posted by robert graham View PostStick a section of wire or heavy monofilament fishing line into that black plastic discharge port....certain mud wasps and spiders like to build nests in those small tubes. Follow that black rubber tube to the metal fitting on the cylinder head if necessary to unplug it...Good Luck!
