I replace the water pump impeller to my 2004 or hp 4 stroke yamaha motor due to No Water Discharge coming from the discharge port when checking to see if I had depleted the problem after replacing the impeller it still remained the same. Someone mentioned that they have had the same problem but found that the discharge port was plugged. Could that be caused the impeller that I removed did look some what good in condition and that it would shoot at least some water from the port. How do I clean the discharge thoroughly if so.
![Frown](https://www.yamahaoutboardparts.com/core/images/smilies/frown.png)
