I recently purchased a Yamaha F300 with all of the needed controls and accessories. I have the digital controls and the Command Link Plus 5" Gauge. I also have the "gateway' (I'm not sure if I need this)... The ignition switch, etc. I have most of it hooked up but I have no wiring diagram. Most of the plugs are pretty self explanatory. I have a Yellow wire with a fuse going to the ignition switch that has a double female bullet style plug, does this get power from my boat or is it used to power something else. Also there is a pair of wires on the back of the gauge Black, Black-pink. Is this for the fuel sender? There is a Blue-White pair as well. The Gateway is part number 6Y98A2D01000 AGI Gateway. I cannot find a wiring diagram anywhere. Any and all help will be appreciated. Thanks for your time.
Yamaha F300 with Command link Plus wiring schematic??
