I obviously have water in my gear oil. I need to know how to remove the 1/2 thick plate under my water pump to get to the drive shaft seal. I tried to pry a lil with a screw driver. what is the best way?
Lower Unit oil milky
Are you certain that the driveshaft seal is the problem?....could be the shifter shaft seal, prop shaft seal or drain/fill plugs seals/washers. Maybe run a pressure test on lower unit to identify the bad seal before ripping into it?...
It is a 90TLRD. 2005 Model. Its the 1/2" plate under the water pump. Why Im on it, Im gonna change all of the seals out.
that plate is a seal carrier.
if your in or near saltwater it does not come out easily and MUST come up straight.
**** it much and you buy a gear case housing.
carefully pry it out.
Im near saltwater. The plate is corroded pretty bad. I have pryed a little but not moving. Just wanted to make sure I was doing the right thing. Maybe I will leave that alone and change out the rest of the seals. I dont want to break anything.
Yamaha 6H1-JD008-73-00 PUMP ADAPTER is the part I am having trouble getting off. It has a gasket under it. What is the best way to remove it?
use the yamaha dealer locator function, find a dealer near you with a master tech and an oxygen/acetylyne rig and it will come out.
ÂÂÂÂÂÂÂÂ
