Hi need some help trouble shooting a no oil transfer problem so far I have the digital gauges. Now reads on yellow low oil the emergence stwich does work but there is no oil transfer under normal operating conditions I changed the control box now going to changes the sending unit in the tank on the boat it does the the letter H stamped on it do you think is will work thanks Rob this is a 1999 S 130 outboard
No oil transfer from main tank to engine oil tank
Tags: None
SWB is in the remote tank.
its a simple ON or OFF switch.
OFF,low tank level, it illuminates the yellow,or center bar, indicate and automatic transfer is INHIBITED.
remember, electroonics are STUPID, almost as bad as some humans.
when ANY part of the circuit for SWB opens, the oil control simply ASSUMES the switch opened.
Thanks Rodbolt I have read most of your threads here about this problem I tested the sending unit with ohm meter and not getting any thing in Esther direction ?? So thinking its bad then going to check the black/ and black/ red wires all the way back to the control Box to see if any breaks in the lines
there is no sending unit.
its an on or off switch.
thats all it does, opens or closes the circuit.
circuit closed it illuminates the green,circuit open it illuminates the yellow.
a quick test you ask? use a set of jumper cables,avalible from radio shack, unplug the 4 pin connector at the remote tank.
jump the black to black red.
turn on the key and you should have a green lamp.
if not jump from black/red to the engine block.
if you now go green its a bad black lead,if not its most likly on the black red.
see how quick and simple this is?
oil still not transferring
Hi Rodbolt17 my new on -off switch came in today and i replaced it in the tank that is in the boat... the yellow light is now off and back to green witch is great the oil level on the engine tank is at its lowest before the buzzer goes off- with the engine running it will still not fill the main engine tank and the emergence switch will work. do you have any more suggestions for me thanks Rob...
Hi i do have question on the module i have a 1999 130 i replaced the module two week ago it came with resistor spark plug caps and my old one did not have these i read on one of rodbolt fourms that i might have a mercury switch under the oil tank might i have this on my engine?? im thinking of going back to the old module to retry it ??? thanks Rob...
