'98 70hp ETLF leaks oil in carbs when tilted
  • '98 70hp ETLF leaks oil in carbs when tilted
    Hi Guys,
    My '98 - 70hp ETLF, oil injected 2-stroke, leaks oil into the carbs when the motor is tilted up. Makes it hard to start, fouls the plugs.
    Once it's been running for a bit, no problems.
    Anybody seen this before?
    Thanks,
    Marco
    MarcosB
    '98 70hp ETLF - 17' Western Alum Center Console
    only when 1 or more of the oil line check valves leak.
    each oil line has a check valve.
    the kien pump had the valves in the pump,the mikuni pumps used inline valves.
    cant remeber when the 3cyl went to mikuni pumps.
      OK, So I took off the oil tank and there are 3 little silver valves, 1 on each oil line coming off the pump. Should I replace them all or can they be tested, cleaned? If they're not too expensive just replace 'em?
      Thanks for the help.
      MarcosB
        expensive is a relative term.
        can they be tested,yep.
        its in the service manual which I dont keep here at my house.
          Oil leak Fixed
          Thanks Rodbolt,
          I removed the check valves and sprayed some solvent in 'em, blew them out with the air compressor, and no more oil in the carbs.
          This forum rocks!
          MarcosB
