I have a 99 C90TLRX and looks like there is oil leaking from the carb throte down into the cowling. Seems to be leaking between the intake/silencer assembly and the stay. First should oil be coming from the carbs like that? And if it is normal would replacing the orings fix the problem? Motor is in the down position in my garage and is leaking down the motor to the garage floor and bulb is not primed.
Oil leaking
Yes not oil injected, premix. I have checked all the fuel lines, no leaks. Not sure about a defective needle valve, and could check that as well. But there seems to be oil leaking from the carb. Could the gas be evaporating leaving the oil to drain down? Only seems to be from the bottom carb. Other 2 seem fine. Thanks for your replies and help.
After sitting in the garage for about 30 days there is a puddle of oil on the floor about 12" in diameter. I left it on purpose to see how much would leak. I think that this is excessive and have checked and tighten all the carb screws and bolts, replaced the orings on the intake/silencer. and checked all the hoses. The gas and oil are coming from the throat of the carb. Any help with what the problem might be and where to start? Thanks in advance
