Have you made sure all cylinders are sealing properly yet?
Hard to make a motor run well if compression is not there.
As I said before spark tester and timing light are simple to find at any auto part store to make sure about those. voltage measurement is the best way to see what is going on but is not necessary unless you see a problem with spark tester or you are not sure of what you see with it
