F115 Tachometer install
  • F115 Tachometer install
    Is the 6Y5-8350T-83-00 Tach compatible with a 2012 F115? If so it looks like I need a harness from the motor. Where would I look to find the correct harness? I repowered a boat with this motor and would like to add a factory tach.
    Thanks for the help,
    Pete
    No that is 1994-2004 engines, use [url=http://www.boats.net/parts/search/parts.html?client=multipart&SKUs=6YR-W0035-E3-00]6YR-W0035-E3-00 Multifunction Tach rig kit[url] includes wiring harness's and it's cheaper.
      Thank you for saving me from ordering the wrong tach!
      I am somewhat mechanical...is the install relatively easy or should I hire it done? Guess this is a "well maybe" type question, hopefully can find a video or procedure to follow.
