Power tgilt/Trim Switchs for 1990 70HP
  • Power tgilt/Trim Switchs for 1990 70HP
    I need to replace the power tilt/trim switches on my Yamaha outboat and on the 703 remote control. I would like to make sure I order the correct parts and also find out if there is anything else I should know about replacing them. Outboard Model # 70TL RO.
    I searched boats.net and found the following part numbers:
    Yamaha 6H1-82563-00-00 TRIM & TILT SWITCH (on the outboard)
    Yamaha 703-82563-01-00 TRIM & TILT SWITCH (on the remote)
    Also, I could not find a part number for Yamaha 2 stroke oil in 1 gallon qty.
    Thanks for the help!!!
    Yes that is right trim switches.
    LUB-2STRK-M1-04 2M 2 stroke oil
