Hi Ken, I am back working on that 115. I received your latest update and have been checking over the fuel system once again. Gas is flowing through the fuel filter and fuel pump when I squeeze the fuel ball. I am figuring that they are both operating fine. Is that assumption correct? I did notice when I took the cover off of the carberators, oil was colleccted in the cover and the water collection/filter tube on the bottom of the oil tank was overflowing. I emptied the small collector tube and reassembled it. I will run those compression tests later today and will let you know what happens. Thanks a lot Ken, Hope you had a great New Years! -Parker
Have a couple of questions before I run the compression tests too. The manual says to disconnect lanyard plate of the engine stop switch, is that the same as a lock plate the manual refers too?
Just to confirm: I take out all the sparks plugs, connect the pressure tester to one, turn the engine over for about 3 seconds and then take reading? Just want to make sure.
Thanks again Ken
Thanks again Ken
