I have a used C115 outboard 1999.
The top carb has the number 6E515 stamped on it, which matches what's in the Yamaha service manual.
The bottom carb is stamped 6R301 and has different bowl drain/jet plugs.
Does anyone know if the top and bottom cards should have different numbers. What is the 6R301 carb, and is the idle screw setting the same as for 6E515 (5/8 turn out)?
