Hi i have an old yamaha tacho with no buttons on the front of the unit and i have no manual with it. The tilt and trim display works an the rpm display works. When first turn on four arrows aling bottom of display show up pointing to different settings i assume? However these then go out and the display stays on rpm. Is this correct, or should it change between settings? Thanks
old yamaha tacho with 98 60feto
