I have a 2001 yamaha badger fourwheeler i just moved back and it has been sitting for a year or two but it is not getting any spark to the sparkplug i got a new sparkpluge and a new sparkplug coil but still nothing all wires are conected so what should i do
fourwheeler
Your on an outboard engine forum....
You may want to check the water in your battery and fully charge as well as do a load test on it.
If there's no juice, it won't fire up the ignition.
You can use a 12 volt car battery to jump start it, just DO NOT HAVE THE CAR ENGINE RUNNING, it will damage the electrics of the 4 wheeler.Scott
Originally posted by justin wright View Postit will turn over and act like it is going to start and i just got a new battery but when it turns over it ant sparking and wont fire up any more ideas
If you have a voltage tester, check the battery, fully charged it should be around 12.8 volts, cranking, it shouldn't drop below 11 volts or so.
I'm assuming it ran before (had spark) when you last used it (and it went into hibernation)?Scott
