Starter Solenoid and Tilt and Trim Problems
  • Starter Solenoid and Tilt and Trim Problems
    Hello All,
    I'm having some issues with the electrical on a 50TLRA. Last weekend I had problems with what seemed to be the starter solenoid. I was getting a buzzing noise from the solenoid but eventually got the motor started. Once I got the boat home I wanted to look and check out the starter solenoid but now the tilt and trim wont go up or down. Can someone please help?
    Load test battery, check condition of battery cables and are clean and tight.
      I have 2 new Batteries and have tried them both.
        Check voltage with a meter at different points while putting a load on system.
        You have a bad connection that can be located with a voltage drop test.
        Bad cable, battery, or just a connection
          Thanks for the help! I found the problem to be the + battery cable. Cable was broken and grounding out on the hull. I cut and replaced the cable and now all is good. Ready for the water! Thanks again for the tips guys.
