1991 200 yamaha 2 volts at buzzer with key on
  • 1991 200 yamaha 2 volts at buzzer with key on
    when the key is in the on position the alarm sounds (barely) and the multimeter reads 2 volts comming to it any ideas???
    does it go off when the engine has started
      I thought at key on there was 12 volts to buzzer and the motor con*****ed the ground to sound it
        check your sensor connections if they are ok check the buzzer they are prone to corrosion its a simple mechanism made up of a thin brass plate that vibrates when power is applied to it open up your control box and give it a clean
          its a new buzzer. and it does not go off when engine is started but it does get louder when oil is low . COULD IT BE A LOW VOLTAGE SIGNAL?
            Is it a Yamaha buzzer?
              no its not .
                could that really be it?
                  I have read about a problem like this before caused by a buzzer from radio shack
                    Yea but 2 volts at it . shouldent there be 0v at it unless something is wrong. Then it should get 12v
                      should have 12V at the yellow buzzer wire at key on.
                      the temp switchs and oil alarm module control the ground path.
                      no ground,no alarm.
                        wheres the oil alarm moduel?
                          on a 1991 200, its part of the CDI unit.
