Help yamaha V4 115 hp not working HELP PLEASE!!!
  • Help yamaha V4 115 hp not working HELP PLEASE!!!
    Ok here is my question.
    Im not very familiar with boats. This is my first one.
    I got a sea NYmph commander with a 115 hp yamaha V4 1190's.
    Oil is on another Tank that auto mix.
    I used the boat few times. To start First i use Choke + Eletric Choke and its goes on first or second time.
    I used the boat few times and i never had a problem. On my 4th time using the boat ever i went out for a longer trip. I stop for a fishing and 40 min latter went to start my engine with out choke and didnt want start. So i keep trying i use the choke didnt want start and then start. Fine no problem. I moved spot for a fishing. when i stop the boat i turn the ignation key on and it was fine. I stay there for couple hours. When i went to leave again no starting the engine. After while it start using choke only.
    I been told i could be starting the engine wrong that i should always use a eletric and normal choke on 2 stroke and because i didnt i could flood the engine thats why.
    Now my question is:
    1 - is that normal to happen could i start wrong and may be flood the engine?
    2- should i pump gas with primer pump every time or not?
    3- could be water on engine as it was a bit rough out there?
    4- Could be a bad connection on my key switch?
    Sorry i got no idea on outboards lol
    If theres any idea of how to test things will be great.
    can you get an owners manual?
    choking a cold two stroke of that vintage is required as is advancing the throttle slightly.
