Me again!!! Just when i thought all was well I checked my lower unit oil and saw some water in it. Upon draining it i got maybe 1 ounce of water and the rest was blurry oil. I took my prop off and no twine was found so i am thinking its my upper seals. I am going to change my upper seals first and go from there.
I have my lower unit off and drained. I have my water pump off and it looks great. I am down to what this part site is calling "cover oil seal", 1)how do i remove this? Seems really tight, I tried to remove it and didn't want to bugger it up so i figured i would ask.
The next item under this is what this site is calling a "Housing water pump", Is this correct? and i assume it pulls off as well. Just kinda figured the water pump housing held the impeller and was above all this and already removed with the metal cup.
I appreciate the help and thank you.
