quick poll
  • quick poll
    Do you guys think flushing out the motor through the hose attachment is enough? or are the ear muffs are better? Share your experiences and opinions please. I just finished cleaning the heads and there was alot of build up around the bottom two cylinders.
    If you're running in saltwater then probably better to use both the flushing attachment and the muffs. Freshwater, maybe get by without the muffs?
      I like running motor while flushing to warm up motor and open stats ,
      and you are not suppose to run motor with just flush hook up,
      so use muffs and the flush to get more water through
