Hook up Yamaha LCD Meter
  • Hook up Yamaha LCD Meter
    Purchased a Boston whaler with a 2003 4 stroke T60C with under 250 hours. Boat has 2 Yamaha LCD meters. The RPM unit is all hooked up, the other unit with Speed/ battery / Gas gauge is not hooked up. I have determined that the separate wire set with a black and Blue provide gauge lamp power
    The 2nd wiring harness has 7 wires, 2 black, one gray, yellow, red, white , and one white with blue stripe.
    Would appreciate a wiring diagram for this gauge.
    Black= ground
    Red = 12 volt power
    Yellow= 12 volts key on power
    Blue= backlight in gauge
    white/ blue= fuel tank sender lead
    Gray= overheat warning light
    white not used
      i think this site http://www.yamahaoutboards.com/rigging/gauges
      could also be of some use to you if they are command link gauges, although the last comment from boats.net is perfect
