2001 HPDI 200hp
motor wont stay running
1,3,5 plugs fouled. Replaced 2 LP pumps that were leaking into the motor. Cleaned VST and checked med pressure (50 psi). Solid spark on all 6 cyls.
I can run the motor for 3 mins after the plugs are cleaned. After that it dies.
It seems like the exhaust is clogged on that bank of cyls. Ive worked on this thing for days. I am about to remove the powerhead and check for an exhaust blockage.. But before I do this any other suggestions?
Thanks for your help...
