2000 Yamaha 30hp Shift rod came out
  • 2000 Yamaha 30hp Shift rod came out
    I was doing some maintenance(water pump) and shift rod seal/boot replacement. and I accidentally pulled the shift rod out of the assembly. Is there a way to get it back in properly? If it means I need to disassemble whole gear case I will do that but I was hoping there is a way to get it back in properly without doing that.
    May be able to push it back down.
      only way to reinsert that shaft is by removing the propshaft.
      once the rod is removed the shift clutch drive pin springs fwd.
      not fun but not bad either.
