6j8-14303-01 carburetor
  • 6j8-14303-01 carburetor
    I never did get an answer to one of my questions in a previous post so i'll try again. I am dealing with the carburetors on a 30f and would like to know if the high speed nozzle(the one underneath) the high speed jet is removable for cleaning. I have tried removing them but it feels as though they are pressed in which makes cleaning the small openings on them problematic. The low speed air flow nozzles are removable, but i don't know what i am dealing with on the high speed and am reluctant to apply too much force. If they can be removed, what would be the proper method for doing so. If they are not removable, how on earth can they be adequately cleaned from time to time. Thanks for any help.
    Should come out by pushing down it through throat of carb, be carefull can be damaged easy then have to buy new carb. If doesn't come out easy then leave it in and soak carb in cleaner.
      Thank you.
