Hard start when cold
  • Hard start when cold
    My fishing partner has a 1998 40MJH 40hp jet, when we try to start the motor when cold you have to crank it up to 20 times,it has done this since new. I don't think Yamaha had this procedure in mind. There dosen't seem to be a choke that I can find. Have read post of other people haveing the same problem,but no real definitive answeres. Once started and warmed up runs great, so I'm thinking fuel.
    Thanks Moe
    What make you think it is a 98?
    You did not post the whole model #.
    Is it a 40 MJHW?
    No choke means prime start model, so you need to make sure that is functioning properly and you have the red switch in the normal position.
    A Yamaha service manual for that motor would help you out a lot
      Is it a 40 MJHW?
      From information given to me, will check into it further
        Model number 40MJHY, where is the red switch you refer to to be in the normal pos.?
          Y is a 2000 model
          red lever on #29 cover, should have sticker on silencer showing positions
          2000 40MJHY Yamaha Outboard CARBURETOR Diagram and Parts
            Can you tell me what that switch does. The manual says for use on emergency cold start. open then start the motor then close it.
            thanks Moe
              You only use it if there is a problem (emergency) to get it started.
              Should be kept in the full counterclockwise position(normal) if motor( carb)is functioning properly
                Seeing the MJHY is manual start and no battery to activate the primer valve, how does the carbs get primed?
                Moe
                  You squeeze the primer bulb to prime the carbs(pump fuel into the bowls)
                  The prime start system is activated when motor cools off, as the motor runs if feeds voltage to the heater unit that closes of the needle as motor heats up
                    10-4 that's what I needed to know. This may have fixed the problem.
                    Thanks Moe
