emergency starter valve position?
  • emergency starter valve position?
    Hello everyone. I have a 1998 90hp 2 stroke. Sometimes I have to use the emergency starter valve to crank my motor after motor hasn't been run in awhile. On the silencer cover there is an illustration showing the normal position and the open position. In the owners manual it says to turn to open position to crank, as I do and it does, but it says to turn it to closed position after it cranks. I don't know if I should leave it there or return it to normal position because the manual doesn't say. This is probably a dumb question but I would like to know. Thanks for any comments.....
