Ticking is appearent at low rpms coming from the upper starboard cylinder rear. Pulled the plug wire off that cylinder (while still running) and noise goes away. Wrist pin or o2 problem? I'm assuming wrist pin.....
Read that you can check play by sticking a dowl through plug hole.
Should this be my next step? thanks
